Problem XOD 0.20.2
hello
I’m french and I use google translation to make me understand on the forum so if there are translation problems I’m sorry in advance !
to better explain the problem I put you the video link from the screenshot that I did to explain.
Vidéo: https://www.youtube.com/watch?v=_fFA12yUwL4
as you can see on the video there are uploading problems do not hesitate to go back or advance on the video.
thank you
Same for me :frowning_face:
I see you have a problem when using digital-input or a node which uses the digital-input inside it (e.g. button). I can’t reproduce, unfortunately. Maybe the problem is caused by some 3rd-party libs? Would you list the list of installed libraries?
Would you check: does a solution from XOD is hanging after actualization solves your problem?
ok i’m looking at this tomorrow i will erase so $WS/lib/xod directory
I’ll keep you informed !
ok it works by clearing the folder “lib”
thank you for this precious help now I will be able to advance on my home automation project to automate all the lamps of my house thank you !
