Modeling error how to solve the problem
prompt in what a problem ???
Building…
=== Skipped 0 lines ===
Non-zero exit code of compiler
XODMAIN.cpp:1190:33: error: use of undeclared identifier ‘LOW’
if (pulseInLength(port, LOW, 70) == 0)
XODMAIN.cpp:1196:43: error: use of undeclared identifier ‘HIGH’
pulseLength = pulseInLength(port, HIGH, 80);
XODMAIN.cpp:1211:24: error: use of undeclared identifier ‘HIGH’
digitalWrite(port, HIGH);
XODMAIN.cpp:1216:5: error: use of undeclared identifier ‘delayMicroseconds’
delayMicroseconds(30);
XODMAIN.cpp:1220:19: error: use of undeclared identifier ‘INPUT_PULLUP’
pinMode(port, INPUT_PULLUP);
XODMAIN.cpp:1222:29: error: use of undeclared identifier ‘LOW’
if (pulseInLength(port, LOW, 90) == 0)
XODMAIN.cpp:1229:29: error: use of undeclared identifier ‘HIGH’
if (pulseInLength(port, HIGH, 90) == 0)
XODMAIN.cpp:1240:24: error: use of undeclared identifier ‘HIGH’
XODMAIN.cpp:1253:24: error: use of undeclared identifier ‘HIGH’
XODMAIN.cpp:1278:28: error: use of undeclared identifier ‘LOW’
digitalWrite(port, LOW);
XODMAIN.cpp:1470:10: fatal error: ‘Wire.h’ file not found
#include <Wire.h>
11 errors generated.
shared:ERROR: compiler frontend failed to generate LLVM bitcode, halting
problem to XOD developers.
Hi, DHT11 and other nodes include arduino library, can not be simulated, use upload and debug
with this more or less clear ,there is a more significant problem when loading and checking the program code in the arduino ide the problem appears
In arduino IDE does not have the library installed LiquidCrystal_i2c
unfortunately, I do not use the desktop version of xod (my operating system does not support it)how can I transfer the library that uses xod in this code??
ah ok …
Although I can not start it, maybe I can extract the library from here, but in the IDE
C:\Users\User\AppData\Local\Programs\XOD IDE\resources\workspace\__ardulib__\LiquidCrystal_I2C
In IDE Arduino > sketch > Include Library > Manage Library > search LiquidCrystal_i2c …install “by Frank de Brabander”
if I understand correctly then xod (in code creation uses a similar library)
Some nodes or libraries XOD use arduino libraries, you can use an i2c device, and create your library with xod/i2c nodes, this will use the wire library.
Wire is a standard library, you will not need to download it for IDE.
the problem remained, did everything according your instructions
Blockquote at first I thought that my 3 like libraries and possible conflict of interest, removed everything leaving only the one (which is from “franc de Brabandere”) the result is the same error
here is the full error message can help to understand:
C:\Users\C39C~1\AppData\local\temp\arduino_modified_sketch_477100\sketch_apr07a folder.Eno: in the ‘void’ function xod::xod__common_hardware__text_lcd_16x2_i2c::evaluate(xod::xod__common_hardware__text_lcd_16x2_i2c::Context)’:
sketch_apr07a:1595: error: no matching function for call to ’ LiquidCrystal_I2C:: begin ()’
     LCD>start();
C:\Users\C39C~1\AppData\Local\Temp\arduino_modified_sketch_477100\sketch_apr07a.ino: 1595: 20: note: candidate:
In the file included from C:\Users\C39C~1\AppData\Local\Temp\arduino_modified_sketch_477100\sketch_apr07a.ino: 1471:0:
C:\Users\кирилл\Documents\Arduino\libraries\LiquidCrystal_I2C/LiquidCrystal_I2C.h:58:8: note: void LiquidCrystal_I2C:: begin(uint8_t, uint8_t, uint8_t)
void begin(uint8_t cols, uint8_t rows, uint8_t charsize = LCD_5x8DOTS );
C:\Users\кирилл\Documents\Arduino\libraries\LiquidCrystal_I2C/LiquidCrystal_I2C.h:58:8: note: candidate expects 3 arguments, 0 provided
Using library wire in folder: C:\Users\кирилл\Documents\Arduino\libraries\Wire (heritage)
Use the library LiquidCrystal_I2C version 1.1.1 from the folder: C:\Users\кирилл\Documents\Arduino\libraries\LiquidCrystal_I2C
output status 1
Yes , sorry for my English I use a translator
replace the library LiquidCrystal_i2c for this
http://image.dfrobot.com/image/data/TOY0046/LiquidCrystal_I2Cv1-1.rar
I have compiled without errors in the IDE
again failure . I don’t think there’s a problem with the library.
most likely a compilation error in xod(xod gives errors in the code )%D0%A1%D0%BD%D0%B8%D0%BC%D0%BE%D0%BA5
1 the arduino ide compiler references the string “begin”
2 no matching function for call to
Use https://github.com/xodio/xod/tree/master/workspace/__ardulib__
I did not realize before these
the link you gave me is a library (LiquidCrystal_I2C) specifically for working with xod code, am I right ???
the problem was solved ! only after I installed the library that Cesars provided me with a link , is it specifically written to work with xod
