Error on upload
Hi all,
Can anybody help me to understand the following error message when trying to upload to a Uno? I am using Version 0.38.0 and the last upload was probably on 0.36.1 when all was ok.
Complete system V4.1.3.xodball (63.6 KB)
Any help would be much appreciated.
I’m able to compile your patch for Arduino Uno using XOD 0.38.0. I suspect that on your system one of the built-in nodes is broken. The following post may contain the solution to your problem:
Thanks Matt for your (lightning quick!) response. Good to know that it is not a problem with my patch. I will delete the Xod folder, restart Xod and see if that sorts it.
Thanks again Matt, the info you supplied sorted the problem.
Also I will take this opportunity to thank you for all the work you do for us XODers.
I am using your avr-sleep library which works a charm controlling some LED’s in a battery driven application. I am able to control both the sequencing of the LED’s as well as the Off/On function with a single push-button.
Kind regards
Mike
