XOD 0.21.0 Released: Byte, Port, and Custom Types
Hi there,
Using the following component produced the error detailed below. This component worked in XOD version 0.20.3 :-
Component:- text-lcd-16x2
xod/common-hardware/text-lcd-16x2
Drives a text LCD screen with HD44780 chip
Error
UNEXPECTED_ERROR {“message”:“Can’t find the patch in the project with specified path: “xod/core/constant-port””}
Hi!
It’s most likely because you have an outdated copy of xod/core library lying around in your workspace. Do you have __lib__/xod folder there? Just delete it and all should be fine.
Thank you,
Found it hanging out here …. $HOME\xod_lib_\xod\core
Renamed it $HOMEC\xod_lib_\xod\core_old (will delete it)
Works fine now.
