Nothing else happens (even after waiting for like 10 minutes).
Is there anything i have to setup for simulation to work or do you have any idea to help me out?
Keep in mind that weekend, the software is free programmers make a great effort. The simulation is new functionality. But you can’t wait to connect a board, debug and compile locally
Upload failed
Command C:\Program Files\XOD IDE\resources\arduino-cli.exe --config-file=C:\Users\user\AppData\Local\Temp\arduino-cli7ElMfn\.cli-config.yml upload --fqbn arduino:avr:uno --port COM5 --verbose -t C:\Users\user\AppData\Local\Temp\xod_temp_sketchbookktmcRu\xod_1574371332667_sketch failed with code 1
