ESP8266 sketch does not compile when using debug watch
If I add a debug watch window to ESP8266 (wemos mini) sketches it results in the following error
note: in expansion of macro ‘F’
  •     XOD_DEBUG_SERIAL.print(F("ERR"));*
Without the debug watch the sketch uploads and works fine.
Is there a particular setting that is needed to get debug watch working for ESP8266 boards?
Update. It now works after updating the Arduino packages and toolchains under the Deploy tab.
