Create a folder library and add libraries, create a folder, nodes> nodes, and add individual nodes.
Up to here it seemed that it was fine, but I kept a xodball and it went wrong to reopen. Edit another and the same error, I opened xodball with Notepad ++ and I see several libraries in a blank patch.
Reinstall and continue the same, until it reaches the library folder that, in my opinion, everything was fine.
There I found after much searching, a folder with capital letters and another with space between the names.
It does not give any error when opening XOD, but corrupts the xodball when saving it
C:\Users\...\xod\__lib__\library\Stepper o C:\Users\....\xod\__lib__\library\dig seg FAIL
If there is a library with capital or space, when saving a project or xodball, the content of those libraries is incorporated into the file and corrupts it, when opening it later it gives an error.
Well, it is a bug, but I am not surprised… The contents of __magic__ directories is not expected to be managed by hands. Furtermore, *.xodball’s are not expected under __lib__ at all, only multifile projects.
I suspect you’re trying to hack the system to make it possible to develop and use a library at the same time? Am I right?
I do not attribute it to being a XOD error, it was to tell what happened in case someone comes up with the same thing and makes the same mistake.
That’s why I broke several files, and had to correct them manually
I have several modified nodes, all loose, I began to sort them, by folders and place them in __lib__
Now everything works ok, I have a folder “nodes/nodes” with all the individual nodes (folder with patch.xodp, cpp, etc)
Another folder library / and several libraries inside, some mine, others modified (folder with project.xod and foders with patch.xodp, cpp, etc).
