XOD 0.32.0 released: Introducing Cloud Feeds
still no support for mega 2560 under debug mode…get the following
new.cpp.o (symbol from plugin): In function operator new(unsigned int)': (.text+0x0): multiple definition of operator new(unsigned int, void*)’
C:\Users\zeidl\AppData\Local\Temp\arduino-sketch-F151DA0857CCF76E8BB662C7EE3A0416\sketch\xod_1575498235533_sketch.ino.cpp.o (symbol from plugin):(.text+0x0): first defined here
c:/users/zeidl/xod/packages/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino5/bin/…/lib/gcc/avr/7.3.0/…/…/…/…/avr/bin/ld.exe: Disabling relaxation: it will not work with multiple definitions
Error: exit status 1
Compilation failed.
Compilation failed
Thanks for the report! The fix is coming.
New version 0.32.1 has been released and it contains a fix for this problem. Just update the IDE :slight_smile:
And thanks for the report one more time!
Gracias
I am so glad all of you are working so hard to make XOD so good, No it is GREAT. Thanks to all of your hard work.
