Hi all, I am brand spanking new to ZOD and electronics in general, and trying to make stuff with small motors.
This is the error code I get while trying to follow along. Has this happened to anyone else? I think I have everything installed properly on my computer.
problem to XOD developers.
Just worked for me. What is happening when you try? Are you using hardware nodes (button, POT, LCD, etc.)? They will never work in simulation because you cannot connect physical hardware to the simulator. You need to replace these inputs and outputs with tweak and watch nodes.
