I wrote some simple logic to work with the stepper 28BYJ-48 but I when I try to publish the library it fails. It returns 404
for /orgs/:username
and for /orgs/:username/libs/:libname
Am I doing something wrong?
for /orgs/:username
hi, yes …version 0.0.0
place at least 0.0.1 and always to update a higher number
I tried with 0.0.1 as well.
It is probably an issue with my account because it is returning 404 for /orgs/txgruppi
and for /orgs/txgruppi/libs/stepper-28byj48
A validation error should not return 404, considering the API respects the HTTP status code standards.
If, in addition to the library version, it can also be a login problem, I forgot about that
I also tried sign in and out several times =/
name only stepper-28byj48
Sorry but I didn’t get it. What about the name?
Only the name of the library, you are placing “user + /”
When a new theme is created, with the title of the library. In the description the link, capture, etc
yes, try to publish now
Same errors. The txgruppi/
is added by the UI, I don’t type it.
sorry , I must think more before writing
You’re right. This is a bug in the API. We did a little work with the wrench and now it should work. Can you try?
It worked!
Thanks!
