Is anyone successfully using bradzilla84/serial-plotter?
I get the following error when I try to compile the example from the library:
… fatal error: ‘Plotter.h’ file not found #include “Plotter.h”
I’ve copy/pasted the ‘Plotter’ library folder that include plotter.h from my Arduino IDE folder to the ‘ardulib’ folder in XOD but to no avail.
Do I need to install the plotter library on XOD somehow?
I was running with a Microsoft (cloud-based) account on Windows 10. The name does have a space in it. So, I created a new local account on the same machine with no space in the username.
I still get the same issue. The log is pasted below.
problem to XOD developers.
Follow log (0 new lines skipped)
