While generating simulator for text-lcd-parallel-16x2 its throwing the below error.
Building…
/ws/sketchbook/ebd63e2f187bfe0184b7fba45ee5ff3f7e11a77e5aec21903f81e758ae3eb88a/sketch/sketch.ino:967:10: fatal error: ‘LiquidCrystal.h’ file not found
#include <LiquidCrystal.h>
1 error generated.
shared:ERROR: ‘/ws/arduino_data/packages/xod/tools/emscripten/1.39.2/bin/clang++ -target wasm32-unknown-emscripten -D__EMSCRIPTEN_major__=1 -D__EMSCRIPTEN_minor__=39 -D__EMSCRIPTEN_tiny__=1 -D_LIBCPP_ABI_VERSION=2 -Dunix -D__unix -D__unix__ -Werror=implicit-function-declaration -Xclang -nostdsysteminc -Xclang -isystem/ws/arduino_data/packages/xod/tools/emscripten/1.39.2/emscripten/system/include/libcxx -Xclang -isystem/ws/arduino_data/packages/xod/tools/emscripten/1.39.2/emscripten/system/lib/libcxxabi/include -Xclang -isystem/ws/arduino_data/packages/xod/tools/emscripten/1.39.2/emscripten/system/include/compat -Xclang -isystem/ws/arduino_data/packages/xod/tools/emscripten/1.39.2/emscripten/system/include -Xclang -isystem/ws/arduino_data/packages/xod/tools/emscripten/1.39.2/emscripten/system/include/libc -Xclang -isystem/ws/arduino_data/packages/xod/tools/emscripten/1.39.2/emscripten/system/lib/libc/musl/arch/emscripten -Xclang -isystem/ws/arduino_data/packages/xod/tools/emscripten/1.39.2/emscripten/system/local/include -DLLVM_ROOT=/ws/arduino_data/packages/xod/tools/emscripten/1.39.2/bin -DARDUINO_WASM_SIMULATION -DARDUINO_ARCH_WASM -O2 -std=c++11 -nostdlib -fno-exceptions -fno-rtti -c -I/tmp/arduino-sketch-B52BD1F65EBD38460B8568F7E7D9E55B/sketch -I/ws/arduino_data/packages/xod/hardware/wasm/0.2.0/cores/simulation -I/ws/arduino_data/packages/xod/hardware/wasm/0.2.0/variants/simulation -DEMSCRIPTEN /tmp/arduino-sketch-B52BD1F65EBD38460B8568F7E7D9E55B/sketch/sketch.ino.cpp -Xclang -isystem/ws/arduino_data/packages/xod/tools/emscripten/1.39.2/emscripten/system/include/SDL -c -o /dev/null -mllvm -combiner-global-alias-analysis=false -mllvm -enable-emscripten-sjlj -mllvm -disable-lsr’ failed (1)
problem to XOD developers.
Follow log (0 new lines skipped)
