The generated C++ code contains errors. Fatal error: 'Wire.h' file not found
Good morning all,
I am trying to develop Stepper Program, based on English Charlies you tube clip
Attached is my version
Pan Stepper to Arduino.xodball (327.9 KB)
I have a C++ error for Fatal error Wire.h which comes up nearly straight away after selecting Simulate, see below.
Other information I have is:
*Simulate does not colour the node red to identify the incorrect node
*The Debugger starts but does not finish
*I get a red circle with a line through next to Deployment
Does anyone know how to fix this?
Thanks in advance
David
/ws/sketchbook/bd7604d2a1469430d67b0bafcc9f5d713dcd9837aee72048a84b5ea26a8e84fb/sketch/sketch.ino:982:10: fatal error: ‘Wire.h’ file not found
#include <Wire.h>
1 error generated.
shared:ERROR: ‘/ws/arduino_data/packages/xod/tools/emscripten/1.39.2/bin/clang++ -target wasm32-unknown-emscripten -D__EMSCRIPTEN_major__=1 -D__EMSCRIPTEN_minor__=39 -D__EMSCRIPTEN_tiny__=1 -D_LIBCPP_ABI_VERSION=2 -Dunix -D__unix -D__unix__ -Werror=implicit-function-declaration -Xclang -nostdsysteminc -Xclang -isystem/ws/arduino_data/packages/xod/tools/emscripten/1.39.2/emscripten/system/include/libcxx -Xclang -isystem/ws/arduino_data/packages/xod/tools/emscripten/1.39.2/emscripten/system/lib/libcxxabi/include -Xclang -isystem/ws/arduino_data/packages/xod/tools/emscripten/1.39.2/emscripten/system/include/compat -Xclang -isystem/ws/arduino_data/packages/xod/tools/emscripten/1.39.2/emscripten/system/include -Xclang -isystem/ws/arduino_data/packages/xod/tools/emscripten/1.39.2/emscripten/system/include/libc -Xclang -isystem/ws/arduino_data/packages/xod/tools/emscripten/1.39.2/emscripten/system/lib/libc/musl/arch/emscripten -Xclang -isystem/ws/arduino_data/packages/xod/tools/emscripten/1.39.2/emscripten/system/local/include -DLLVM_ROOT=/ws/arduino_data/packages/xod/tools/emscripten/1.39.2/bin -DARDUINO_WASM_SIMULATION -DARDUINO_ARCH_WASM -O2 -std=c++11 -nostdlib -fno-exceptions -fno-rtti -c -I/tmp/arduino-sketch-9E84595BF5F9208EF4448DC4101AC35C/sketch -I/ws/arduino_data/packages/xod/hardware/wasm/0.3.2/cores/simulation -I/ws/arduino_data/packages/xod/hardware/wasm/0.3.2/variants/simulation -DEMSCRIPTEN /tmp/arduino-sketch-9E84595BF5F9208EF4448DC4101AC35C/sketch/sketch.ino.cpp -Xclang -isystem/ws/arduino_data/packages/xod/tools/emscripten/1.39.2/emscripten/system/include/SDL -c -o /dev/null -mllvm -combiner-global-alias-analysis=false -mllvm -enable-emscripten-sjlj -mllvm -disable-lsr’ failed (1)
problem to XOD developers.
Hi David,
Unfortunately it is not possible to simulate hardware devices. See:
