I was doing tests, modifying this library, this bug appeared (frozen search node)
edit: help with H does not work
Thank you for reporting!
Do you have a stable scenario to reproduce the problem? I can’t get the same behavior.
What happens if you double-click the patch board? What happens if you’re typing something in the search field?
Again try to modify the library successfully and the problem did not arise ![]()
Search and Help did not work, if you could insert nodes, save, etc.
It seems to be a small crash, it appeared when looking at XOD / core / to replace gate-input, first Help did not close, manually close and then I went to (x) and could not close.
If I could not see the search field ![]()
thank
I found the problem, I went on to detail what happens
1- Search with “I”
2- Display the list, and select a node to see help (xod / 7core / input
3- Without closing look in Toggle Ispector
4- Search field and frozen list.
5- I close in x, but when it reaches the search field, it remains open.
Maybe it’s my mistake to search and go to the inspector, or not and I should block the selection, or close the search field automatically ![]()
Edit:
when looking for a node in the field it closed ![]()
