Rotary encoder solution
Is there a solution for rotary encoder? i want to make menu with different pages in a screen.
age3only/rotary-encoder-with-button
Please try install this library, I create this library when i felt similar problem,
This Library will simplify, connecting a rotary encoder hardware (With Push button-switch).
According to the LCD type ,the menu part in LCD you have to manage .
i will modify the library if u felt any issues .
(am new in coding )
dear age3only
i can’t find you it in the libary
There are several other encoder options: https://xod.io/libs/?q=encoder
I’ll chk it …
get me some time pls …
