Patch for RGB LED Driver Module
Hello. I am not good at programming. I would like to know if there is a patch for RGB LED Driver Module?
If you search for RGB in the library (https://xod.io/libs/?q=rgb) there are a couple options that might help you get started.
Thank you very much for the library. I have such a module. and it is driven by 2 wires. how to do it right? nk could give an example? thank you so much
