I upgraded to build 0.25.0.4842 and added support for WeMos D1 but when I when to upload I have no USB serial port
I have tried different boards (Uno and the D1) no difference. Also changed USB cables and on a MacBook Pro with USB C if that makes a difference.
Have gone to the Arduino IDE and I get a serial port which points me back here - Help
Update just installed XOD 25.1 on a MBA with 10.13.6
same problem no useful serial ports just:
/dev/tty.chrissAirPods-Wirelessi-2
dev/tty.Bluetooth-Incoming-Port
Upgrading original MBpro now
Ok no luck after update to 25.1 but just tried a UNO and it finds / creates a port:
/dev/tyy.usbmodem14301 which I would expect so seems to be a WeMos D1 issue
any help welcome - I’m a noob so be gentle
Hello and welcome!
Have you tried to install a driver from https://wiki.wemos.cc/products:d1:d1_mini ?
No I hadn’t but I have now but sadly no difference.
I tried twice and followed the instructions in the read.me
If I open terminal and do ls /dev/tty* there is only the ports mentioned prior
thoughts?
