MPU 6050 and arduino nano are freezing
Hello, i am using MPU 6050 and arduino nano in a project. Using mpu6050 calibrate node , i can calibrate the node and run the node. But after calibrating, the gyro and arduino are running well for 5 minutes. After that the both mpu6050 and arduino freezes and not showing any error in watch node. I have to reset the nano board to run again. But this issue is repeating again and again. Please help
Can you post the XOD code you are using?
