Getting error while calibrating MPU6050
I am trying to calibrate MPU6050 but this error in page is constantly unable to deploy. I have tired third party required libraries. I don’t what wrong.
gabbapeople library used for it.
Future any guidance on Arduino + MPU6050 + L293D Motor Diver self balancing bot would be highly appreciated.
hi, attach the detail of the error, copy what is on the red and paste it here.
compilation terminated.
Error: exit status 1
Compilation failed.
Compilation failed
Command C:\Program Files\XOD IDE\resources\arduino-cli.exe --config-file=C:\Users\ayub\AppData\Local\Temp\arduino-clirfSG9S\.cli-config.yml compile --fqbn arduino:avr:mega:cpu=atmega2560 --verbose C:\Users\ayub\AppData\Local\Temp\xod_temp_sketchbookZRoUXb\xod_1553498402219_sketch failed with code 1
This basically just says “There were errors above”. You need to scroll back to see the actual errors.
@gweimer: now, i am facing new problem. my code for calibration has been uploaded somehow. but not getting any reading wires are connected as they should. please guide me on this.
Std Arduino issue probably…board initializes communication before XOD is ready to receive. Reset board after program is uploaded and XOD is ready & watch nodes should start displaying data.
@gweimer: as you said i have done the same it display values only 0 for all axis.
You need to send a signal to the INIT pin. You can use a clock node to send signals repeatedly, or a boot and defer nodes to send a signal soon after boot.
tried Boot + Defer it worked but it stops not working constitutionally. Tried clock its not working. Don’t know how it work.
By default, clock node will provide a pulse every second. The clock-TICK pin should be connected to the INIT pin of your calibrate node. If calibrate takes longer than 1 second, you should increase the clock-IVAL time.
:shushing_face: not working in my case.
