MPU 6050 Failed Communications
Okay, so I am new to XOD and trying to use the gabbapeople/mpu6050 library. I am interfacing a SEN0142/MPU6050 to a standard Arduino Uno. Everything works okay in the Arduino IDE. I have the MPU6050 connected to the UNO via SCL>A5; SDA>A4; INT>2. However, when I run it in XOD I get the following Upload Failure message:
Traceback (most recent call last):
File “C:\Users\deana\xod_packages_\packages\esp8266\hardware\esp8266\2.7.4/tools/upload.py”, line 65, in
esptool.main(cmdline)
File “C:/Users/deana/xod/packages/packages/esp8266/hardware/esp8266/2.7.4/tools/esptool\esptool.py”, line 2890, in main
esp.connect(args.before)
File “C:/Users/deana/xod/packages/packages/esp8266/hardware/esp8266/2.7.4/tools/esptool\esptool.py”, line 483, in connect
raise FatalError(‘Failed to connect to %s: %s’ % (self.CHIP_NAME, last_error))
esptool.FatalError: Failed to connect to ESP8266: Timed out waiting for packet header
Error during Upload: uploading error: uploading error: exit status 1
Upload failed
I’ve tried everything I can think of to resolve?
If you have an Uno, I don’t think XOD should be trying to connect to ESP8266. Sounds like you are selecting the wrong model when you do the upload. I use board model “Arduino Uno WiFi” when uploading to an Uno board.
