Upload issues Esp 8266
3 months ago I uploaded in Version 0.32ff a file to a D1 mini clone from AZ-Delivery using the following parameters.
the programm runs since than.
In XOD version 0.36.1 I always get the Error message below. Nanos can be programmed without problems.
I don’t know what the problem could be, pls help me solve the problem.
I tested other ESP 8266 paramketer sets receiving the same message :“No new serial port detected.”
Waiting for upload port…
“C:\Users\vattern\XOD_packages_\packages\esp8266\tools\esptool\0.4.13/esptool.exe” -vv -cd nodemcu -cb 115200 -cp “COM6” -ca “0x3FC000” -cz 0x4000 -ca 0x00000 -cf “C:\Users\vattern\AppData\Local\Temp\xod_temp_sketchbook8AKrwJ\xod_1607976627432_sketch\build\esp8266.esp8266.nodemcuv2/xod_1607976627432_sketch.ino.bin”
esptool v0.4.13 - © 2014 Ch. Klippel ck@atelier-klippel.de
setting board to nodemcu
setting baudrate from 115200 to 115200
setting port from COM1 to COM6
setting address from 0x00000000 to 0x003FC000
setting erase size to 0x00004000
error: Failed to open COM6
error: espcomm_open failed
Error during Upload: uploading error: uploading error: exit status 2
Upload failed
Dear 13uli,
try Wemos D1 R1 Board Model or Generic ESP8266 Model.
Greez
Chris
