How to wire a 2.4" TFT lcd mcufriend to arduino uno
Can somebody please explain how to wire a 2.4"TFT lcd screen to arduino uno?
I used the library bradzilla84/example 1 but my screen stays white and no images are shown.
I just plugged the TFT lcd screen on top of the arduino uno.
Maybe i have to unconnect the screen and wire it to the arduino uno?
At first glance, the pinout in the example is wrong (CS & RS)
Thanks very much cesars for your help. I have got the lcd running…GREAT!
Do you also know how i can read the Tf-SD card onboard of the 2.4 "tft-lcd and display it on the screen?
I only can find SD-log in the XOD library to write to a SD Card MEM module.
Is there a node to read from this SD card onboard of the 2.4"TFT-lcd?
Thanks in advance, Best regards, Pyropeet
I think the sd-log node with D10 should work.
Thanks for the info.
Yes i can write something into the sd-log with D10 but i am looking for a node so i can read the bitmap from the sd-card.
This bitmap i want to print on the lcd screen.
Do you know some tools how to do this?
Thanks in advance, Pyropeet
Hi, How Did You get your TFT lcd working and did you use XOD.
If so could you please tell me what you did and how you did it?
Thank You!!!
Hi Abrisco55,
This is how my xod file looks like and i installed the bradzilla84 library.
You can see the connection of the tft lcd device and the touch-device.
Good luck…
Pyropeet
