cesars
December 22, 2018, 7:12pm
1
This could be related to this topic idea-show-values-of-nodes-inputs-on-nodes , although what I can think of is something about constants , what added to change value in patch would give a greater feature to the node (in my opinion)
Here is an example, if I create a node with constants, to be part of a project are hidden
when using it in another project …
@nkrkv what possibility is there to add an option to show-hide? or I’m complicating things
nkrkv
December 27, 2018, 12:16pm
2
I’m sorry if I do not understand correctly. Are you talking about the following?
You are creating a new patch pi
You put a single constant-number there with value bound to 3.14159
You add an output terminal and link the constant with it
Now you put a node of pi on patch main
You see the lable pi on it, but would better see 3.14159
Right?
cesars
December 27, 2018, 1:06pm
3
yes, something like that would be
ps: Thinking well there is not much sense, because with a label it would be solved, the idea arose looking for a way to do something that would work like this with bool, and output byte
cesars
December 30, 2018, 11:29pm
4
if I change the name to a constant I stop seeing the value
I would like something like that
