Change constant value in patch?
When I have a constant node, and I see the value I always double-click trying to change it directly :face_with_raised_eyebrow:
@nkrkv Is there any possibility of changing the value directly?
Sounds reasonable. Created https://github.com/xodio/xod/issues/1586
Thank you.
Any news? How do I change the value of a constant? (boolean, integer/whatever).
Hi, in inspector “val” , label and description
I’ve done it.
Here is a pull request, you can check it out: https://github.com/xodio/xod/pull/1599
Or wait for the coming release. I hope it will get into it :slight_smile:
Great ! :clap::clap:
Available starting from 0.26.0
