just started to use xOD programming. looking for nodes i.e. map-clip-range and map-range as used in dronebot tutorial
The easiest solution is to double-click in the work space where you want to place a new node. That should bring up a search bar. Type in the name of the node, or part of the name, and select from the list of nodes that is found. This avoids scrolling through multiple libraries searching or having to know where they are located (and is an easy way to discover new nodes for a topic if you can guess the right name). The search (or node inspector after you add a node) will tell you where it finds each node.
