Fault message when transfering programm to Arduino Uno
Hi all,
I just downloaded the XOD programm. Works great is is very intuitive. Only problem is that I can’t upload to my Arduino Uno. I keep getting this code:
(see picture)
Any advice?
I re-installed XOD and Arduino IDE, no result…
Windows 10, 64bit.
Hello and welcome!
:face_with_monocle: I saw this error once. The reason was in a Kaspersky antivirus is running. I don’t understand why it changes the certificate chain, but disabling it for the time of the toolchain download (happens once) solved the issue.
Do you have any aggressive anti-virus software? Can you download the archive from the given URL with your browser?
Hi nkrkv,
Thanks for the quick response.
I do indeed have a Kaspersky antivirus running.
The liberary in the link did got downloaded, but I don’t know what to do with it now. Can I insert the file somwere?
Hi,
I disabled my Kaspersky, deleted XOD, and downloaded it again.
Now XOD is stuck on:
It does not stuck, it downloads and unzips. It can take up to few minutes. Try to wait a little longer.
Hi nkrkv,
I tried it several times now. 1h, 4h, Whole night… It will not load/install.
Any idea?
I think the archive became damaged after the first interruption. You can try to manually delete it and try again or setup the toolchain manually. See Can I manualy install the toolchain?
Hi,
Thanks for all the info.
I could not fix the problem, took a second PC, installed it there. It works fine on that one.
I’ll try it again one day soon.
