Tool chain certificate
brand spanking new to xod, fairly new to audrinuo, been reading and reading on forum rules, and forum topics. So my problem “tool chain certificate self signed”, read a couple forums on this, downloaded user/%username%/AppData/Roaming/xod-client-electron/packages/arduino/avr/boards.txt the instructions to insert/install this were not very clear, and I am running win7 so the mac example did not resemble what i found when I navigated to the folder. I love the concept of xod, but if I cant even upload to make it to the 3rd step of the tutorials it is dead before even starting. from what i read kasperski could be part of the problem, cant figure out how to make an exception for xod, and cant remember/ find how to pause kasperski. surely some one on here must have experienced these specific issues that can pass on the solution, pls help if you can? am I in over my head? usually that is determined by ones determination, by stubbornness alone I will often stumble upon the answer even if only by chance.
so I figured out how to pause kaspersky, and got this, Upload failed. ChildProcessError: Command failed: “C:\Users\pauls hot rod\AppData\Local\Programs\XOD IDE\resources\arduino-builder\arduino-builder.exe” -hardware=“C:\Users\pauls hot rod\AppData\Local\Programs\XOD IDE\resources\arduino-builder\hardware” -hardware=“C:\Users\pauls hot rod\AppData\Roaming\xod-client-electron\packages” -libraries=“C:\Users\pauls hot rod\AppData\Local\Programs\XOD IDE\resources\workspace_ardulib_” -tools=“C:\Users\pauls hot rod\AppData\Local\Programs\XOD IDE\resources\arduino-builder\tools” -tools=“C:\Users\pauls hot rod\AppData\Roaming\xod-client-electron\packages” -fqbn=“arduino:avr:uno” -build-path=“C:\Users\pauls hot rod\AppData\Roaming\xod-client-electron\upload-temp\build” “C:\Users\pauls hot rod\AppData\Roaming\xod-client-electron\upload-temp\xod-arduino-sketch.cpp”
c:\users\pauls hot rod\appdata\roaming\xod-client-electron\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2\bin…/lib/gcc/avr/4.9.2/…/…/…/…/avr/bin/ar.exe: unable to rename ‘C:\Users\pauls hot rod\AppData\Roaming\xod-client-electron\upload-temp\build\core\core.a’; reason: File exists
exit status 1
"C:\Users\pauls hot rod\AppData\Local\Programs\XOD IDE\resources\arduino-builder\arduino-builder.exe" -hardware="C:\Users\pauls hot rod\AppData\Local\Programs\XOD IDE\resources\arduino-builder\hardware" -hardware="C:\Users\pauls hot rod\AppData\Roaming\xod-client-electron\packages" -libraries="C:\Users\pauls hot rod\AppData\Local\Programs\XOD IDE\resources\workspace\__ardulib__" -tools="C:\Users\pauls hot rod\AppData\Local\Programs\XOD IDE\resources\arduino-builder\tools" -tools="C:\Users\pauls hot rod\AppData\Roaming\xod-client-electron\packages" -fqbn="arduino:avr:uno" -build-path="C:\Users\pauls hot rod\AppData\Roaming\xod-client-electron\upload-temp\build" "C:\Users\pauls hot rod\AppData\Roaming\xod-client-electron\upload-temp\xod-arduino-sketch.cpp" (exited with error code 1)
exit status 1
Weird.
All I can suggest for now is to try to remove the C:\Users\pauls hot rod\AppData\Roaming\xod-client-electron\upload-temp directory.
k ill try that thank you, being a temp directory means it cant hurt any thing by deleting it right?
Yes, that’s right. It is re-created automatically when necessary.
If you still have the problem, version 0.25.0 should fix it as we changed the mechanics of toolchains installation.
