Error with digital-write
This simple patch gives me an error.
In order to compile I have to comment this line in digital-write node
//#pragma XOD evaluate_on_pin disable
error:
Begin compiling code for the board Arduino Uno 📦
C:\Users\Cesar\AppData\Local\Temp\xod_temp_sketchbook98XhiA\xod_1601190379205_sketch\xod_1601190379205_sketch.ino: In function 'void xod::detail::handleDebugProtocolMessages()':
C:\Users\Cesar\AppData\Local\Temp\xod_temp_sketchbook98XhiA\xod_1601190379205_sketch\xod_1601190379205_sketch.ino:1331:35: error: 'struct xod::TransactionState' has no member named 'node_0_isOutputDirty_OUT'; did you mean 'node_2_isOutputDirty_TICK'?
                     g_transaction.node_0_isOutputDirty_OUT = true;
C:\Users\Cesar\AppData\Local\Temp\xod_temp_sketchbook98XhiA\xod_1601190379205_sketch\xod_1601190379205_sketch.ino: In function 'void xod::runTransaction()':
C:\Users\Cesar\AppData\Local\Temp\xod_temp_sketchbook98XhiA\xod_1601190379205_sketch\xod_1601190379205_sketch.ino:1391:55: error: 'struct xod::TransactionState' has no member named 'node_0_isOutputDirty_OUT'; did you mean 'node_2_isOutputDirty_TICK'?
             ctxObj._isOutputDirty_OUT = g_transaction.node_0_isOutputDirty_OUT;
Compilation failed
Hello. I had exactly the same error. And I also fixed it by deleting or commenting out this line. This bug is related to tweak. It works with other nodes, but doesn’t work with tweak.
By the way, I still don’t understand what function they perform
#pragma XOD evaluate_on_pin enable input_UPD
#pragma XOD error_raise enable
Very strange, I was able to fix the error without changing the patch.
As you can see, I just drew another line from the tweak to another patch
Thanks for commenting, I noticed something similar before when writing a library, if I added the line and had digita-write nodes, the error would appear.
Now this seems to be a bug.
I also see that the c ++ implementation of your node does not seem to be updated to 0.35.x
No, I have the most recent version. I honestly don’t know why the patch hasn’t been updated. And by the way, even if there is a new version, you can still write in the old way.
There is a fork of the xod folder inside libraries, delete it and start xod again.
If you’ve ever moved a node or changed something, a copy of the folder is created.
This change occurs when you save any patch.
Thanks for the report.
Just released a new version 0.35.3 with the fix of this problem.
