Hi, My sketch was working OK on the older version ow it did and upgrade I get the following error when trying to compile. Any ideas as I just need a simple change for a project in a few hours.
Or do I delete and try putting a previous version on?
Begin compiling code for the board Arduino/Genuino Uno
Using board ‘uno’ from platform in folder: C:\Users\Video\xod_packages_\packages\arduino\hardware\avr\1.6.23
Using core ‘arduino’ from platform in folder: C:\Users\Video\xod_packages_\packages\arduino\hardware\avr\1.6.23
Detecting libraries used…
“C:\Users\Video\xod\packages\packages\arduino\tools\avr-gcc\5.4.0-atmel3.6.1-arduino2/bin/avr-g++” -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR “-IC:\Users\Video\xod\packages\packages\arduino\hardware\avr\1.6.23\cores\arduino” “-IC:\Users\Video\xod\packages\packages\arduino\hardware\avr\1.6.23\variants\standard” “C:\Users\Video\AppData\Local\Temp\arduino-sketch-2908F30684AF05C9206E2A5C782D91A8\sketch\xod_1567176454261_sketch.ino.cpp” -o nul
Alternatives for Wire.h: [Wire@1.0]
ResolveLibrary(Wire.h)
-> candidates: [Wire@1.0]
“C:\Users\Video\xod\packages\packages\arduino\tools\avr-gcc\5.4.0-atmel3.6.1-arduino2/bin/avr-g++” -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR “-IC:\Users\Video\xod\packages\packages\arduino\hardware\avr\1.6.23\cores\arduino” “-IC:\Users\Video\xod\packages\packages\arduino\hardware\avr\1.6.23\variants\standard” “-IC:\Users\Video\xod\packages\packages\arduino\hardware\avr\1.6.23\libraries\Wire\src” “C:\Users\Video\AppData\Local\Temp\arduino-sketch-2908F30684AF05C9206E2A5C782D91A8\sketch\xod_1567176454261_sketch.ino.cpp” -o nul
Alternatives for LiquidCrystal_I2C.h: [LiquidCrystal_I2C]
ResolveLibrary(LiquidCrystal_I2C.h)
-> candidates: [LiquidCrystal_I2C]
“C:\Users\Video\xod\packages\packages\arduino\tools\avr-gcc\5.4.0-atmel3.6.1-arduino2/bin/avr-g++” -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR “-IC:\Users\Video\xod\packages\packages\arduino\hardware\avr\1.6.23\cores\arduino” “-IC:\Users\Video\xod\packages\packages\arduino\hardware\avr\1.6.23\variants\standard” “-IC:\Users\Video\xod\packages\packages\arduino\hardware\avr\1.6.23\libraries\Wire\src” “-IC:\Users\Video\AppData\Local\Temp\xod_temp_sketchbookTfXbMn\libraries\LiquidCrystal_I2C” “C:\Users\Video\AppData\Local\Temp\arduino-sketch-2908F30684AF05C9206E2A5C782D91A8\sketch\xod_1567176454261_sketch.ino.cpp” -o nul
“C:\Users\Video\xod\packages\packages\arduino\tools\avr-gcc\5.4.0-atmel3.6.1-arduino2/bin/avr-g++” -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR “-IC:\Users\Video\xod\packages\packages\arduino\hardware\avr\1.6.23\cores\arduino” “-IC:\Users\Video\xod\packages\packages\arduino\hardware\avr\1.6.23\variants\standard” “-IC:\Users\Video\xod\packages\packages\arduino\hardware\avr\1.6.23\libraries\Wire\src” “-IC:\Users\Video\AppData\Local\Temp\xod_temp_sketchbookTfXbMn\libraries\LiquidCrystal_I2C” “C:\Users\Video\xod\packages\packages\arduino\hardware\avr\1.6.23\libraries\Wire\src\Wire.cpp” -o nul
“C:\Users\Video\xod\packages\packages\arduino\tools\avr-gcc\5.4.0-atmel3.6.1-arduino2/bin/avr-g++” -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR “-IC:\Users\Video\xod\packages\packages\arduino\hardware\avr\1.6.23\cores\arduino” “-IC:\Users\Video\xod\packages\packages\arduino\hardware\avr\1.6.23\variants\standard” “-IC:\Users\Video\xod\packages\packages\arduino\hardware\avr\1.6.23\libraries\Wire\src” “-IC:\Users\Video\AppData\Local\Temp\xod_temp_sketchbookTfXbMn\libraries\LiquidCrystal_I2C” “C:\Users\Video\xod\packages\packages\arduino\hardware\avr\1.6.23\libraries\Wire\src\utility\twi.c” -o nul
“C:\Users\Video\xod\packages\packages\arduino\tools\avr-gcc\5.4.0-atmel3.6.1-arduino2/bin/avr-g++” -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR “-IC:\Users\Video\xod\packages\packages\arduino\hardware\avr\1.6.23\cores\arduino” “-IC:\Users\Video\xod\packages\packages\arduino\hardware\avr\1.6.23\variants\standard” “-IC:\Users\Video\xod\packages\packages\arduino\hardware\avr\1.6.23\libraries\Wire\src” “-IC:\Users\Video\AppData\Local\Temp\xod_temp_sketchbookTfXbMn\libraries\LiquidCrystal_I2C” “C:\Users\Video\AppData\Local\Temp\xod_temp_sketchbookTfXbMn\libraries\LiquidCrystal_I2C\LiquidCrystal_I2C.cpp” -o nul
“C:\Users\Video\xod\packages\packages\arduino\tools\avr-gcc\5.4.0-atmel3.6.1-arduino2/bin/avr-g++” -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR “-IC:\Users\Video\xod\packages\packages\arduino\hardware\avr\1.6.23\cores\arduino” “-IC:\Users\Video\xod\packages\packages\arduino\hardware\avr\1.6.23\variants\standard” “-IC:\Users\Video\xod\packages\packages\arduino\hardware\avr\1.6.23\libraries\Wire\src” “-IC:\Users\Video\AppData\Local\Temp\xod_temp_sketchbookTfXbMn\libraries\LiquidCrystal_I2C” “C:\Users\Video\AppData\Local\Temp\arduino-sketch-2908F30684AF05C9206E2A5C782D91A8\sketch\xod_1567176454261_sketch.ino.cpp” -o “C:\Users\Video\AppData\Local\Temp\arduino-sketch-2908F30684AF05C9206E2A5C782D91A8\preproc\ctags_target_for_gcc_minus_e.cpp”
“C:\Users\Video\xod\packages\packages\builtin\tools\ctags\5.8-arduino11/ctags” -u --language-force=c++ -f - --c+±kinds=svpf --fields=KSTtzns --line-directives “C:\Users\Video\AppData\Local\Temp\arduino-sketch-2908F30684AF05C9206E2A5C782D91A8\preproc\ctags_target_for_gcc_minus_e.cpp”
Compiling sketch…
“C:\Users\Video\xod\packages\packages\arduino\tools\avr-gcc\5.4.0-atmel3.6.1-arduino2/bin/avr-g++” -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR “-IC:\Users\Video\xod\packages\packages\arduino\hardware\avr\1.6.23\cores\arduino” “-IC:\Users\Video\xod\packages\packages\arduino\hardware\avr\1.6.23\variants\standard” “-IC:\Users\Video\xod\packages\packages\arduino\hardware\avr\1.6.23\libraries\Wire\src” “-IC:\Users\Video\AppData\Local\Temp\xod_temp_sketchbookTfXbMn\libraries\LiquidCrystal_I2C” “C:\Users\Video\AppData\Local\Temp\arduino-sketch-2908F30684AF05C9206E2A5C782D91A8\sketch\xod_1567176454261_sketch.ino.cpp” -o “C:\Users\Video\AppData\Local\Temp\arduino-sketch-2908F30684AF05C9206E2A5C782D91A8\sketch\xod_1567176454261_sketch.ino.cpp.o”
C:\Users\Video\AppData\Local\Temp\xod_temp_sketchbookTfXbMn\xod_1567176454261_sketch\xod_1567176454261_sketch.ino: In function ‘void xod::runTransaction()’:
C:\Users\Video\AppData\Local\Temp\xod_temp_sketchbookTfXbMn\xod_1567176454261_sketch\xod_1567176454261_sketch.ino:3728:26: error: ‘struct xod::xod__core__defer_pulse::Node’ has no member named ‘errorFlags’
if (!node_55.errorFlags) {
C:\Users\Video\AppData\Local\Temp\xod_temp_sketchbookTfXbMn\xod_1567176454261_sketch\xod_1567176454261_sketch.ino:3735:24: error: ‘struct xod::xod__core__defer_pulse::ContextObject’ has no member named ‘_error_input_IN’
ctxObj._error_input_IN = 0;
C:\Users\Video\AppData\Local\Temp\xod_temp_sketchbookTfXbMn\xod_1567176454261_sketch\xod_1567176454261_sketch.ino:3741:73: error: ‘struct xod::xod__core__defer_pulse::Node’ has no member named ‘errorFlags’
node_1.isNodeDirty |= (node_55.isOutputDirty_OUT || node_55.errorFlags);
Multiple libraries were found for “Wire.h”
Used: C:\Users\Video\xod_packages_\packages\arduino\hardware\avr\1.6.23\libraries\Wire
Multiple libraries were found for “LiquidCrystal_I2C.h”
Used: C:\Users\Video\AppData\Local\Temp\xod_temp_sketchbookTfXbMn\libraries\LiquidCrystal_I2C
Using library Wire at version 1.0 in folder: C:\Users\Video\xod_packages_\packages\arduino\hardware\avr\1.6.23\libraries\Wire
Using library LiquidCrystal_I2C in folder: C:\Users\Video\AppData\Local\Temp\xod_temp_sketchbookTfXbMn\libraries\LiquidCrystal_I2C (legacy)
Error: exit status 1
Compilation failed.
Compilation failed
Command C:\Program Files\XOD IDE\resources\arduino-cli.exe --config-file=C:\Users\Video\AppData\Local\Temp\arduino-cli9q3Syg\.cli-config.yml compile --fqbn arduino:avr:uno --verbose C:\Users\Video\AppData\Local\Temp\xod_temp_sketchbookTfXbMn\xod_1567176454261_sketch failed with code 1
