Compilation failed
Command C:\Users\taran\AppData\Local\Programs\XOD IDE\resources\arduino-cli.exe --config-file=C:\Users\taran\AppData\Local\Temp\arduino-cliPhNTZ9\.cli-config.yml compile --fqbn arduino:avr:uno --verbose C:\Users\taran\AppData\Local\Temp\xod_temp_sketchbookJfbjR2\xod_1551833061939_sketch failed with code 1
Try generation the C++ code, open the Arduino IDE, paste the code there and see what errors you get.
link to code is:
https://pastebin.com/Pi6zQTGv
