Can't upload anything to any board
I can’t upload anything to either my Uno or my Nano. I was able to bypass this by using cloud compile, but that stopped working last night it just hangs and doesn’t complete. This is what XOD is telling me:
Project was successfully transpiled. Searching for device…
Port with connected Arduino was found. Installing toolchains…
Toolchain is installed. Compiling…
Upload failed. ChildProcessError: Command failed: “C:\Program Files\XOD IDE\resources\arduino-builder\arduino-builder.exe” -hardware=“C:\Program Files\XOD IDE\resources\arduino-builder\hardware” -hardware=“C:\Users\Crass\AppData\Roaming\xod-client-electron\packages” -libraries=“C:\Program Files\XOD IDE\resources\app.asar\src-babel\workspace_ardulib_” -tools=“C:\Program Files\XOD IDE\resources\arduino-builder\tools” -tools=“C:\Users\Crass\AppData\Roaming\xod-client-electron\packages” -fqbn=“arduino:avr:nano:cpu=atmega328” -build-path=“C:\Users\Crass\AppData\Roaming\xod-client-electron\upload-temp\build” “C:\Users\Crass\AppData\Roaming\xod-client-electron\upload-temp\xod-arduino-sketch.cpp”
open C:\Program Files\XOD IDE\resources\app.asar\src-babel\workspace_ardulib_: The system cannot find the path specified.
"C:\Program Files\XOD IDE\resources\arduino-builder\arduino-builder.exe" -hardware="C:\Program Files\XOD IDE\resources\arduino-builder\hardware" -hardware="C:\Users\Crass\AppData\Roaming\xod-client-electron\packages" -libraries="C:\Program Files\XOD IDE\resources\app.asar\src-babel\workspace\__ardulib__" -tools="C:\Program Files\XOD IDE\resources\arduino-builder\tools" -tools="C:\Users\Crass\AppData\Roaming\xod-client-electron\packages" -fqbn="arduino:avr:nano:cpu=atmega328" -build-path="C:\Users\Crass\AppData\Roaming\xod-client-electron\upload-temp\build" "C:\Users\Crass\AppData\Roaming\xod-client-electron\upload-temp\xod-arduino-sketch.cpp" (exited with error code 1)
Looks like you are on 0.24.0. It has a bug you’ve mentioned. Try to upgrade to 0.24.1 and upload again.
Thanks, problem solved!
