0.24 upgrade fail
I clicked the button to upgrade 0.23 to 0.24 and now I get errors when uploading.
Any ideas what is causing this?
Project was successfully transpiled. Searching for device…
Port with connected Arduino was found. Installing toolchains…
Toolchain is installed. Compiling…
Upload failed. ChildProcessError: Command failed: “/Applications/XOD IDE.app/Contents/Resources/arduino-builder/arduino-builder” -hardware="/Applications/XOD IDE.app/Contents/Resources/arduino-builder/hardware" -hardware="/Users/testuser/Library/Application Support/xod-client-electron/packages" -libraries="/Applications/XOD IDE.app/Contents/Resources/app.asar/src-babel/workspace/ardulib" -tools="/Applications/XOD IDE.app/Contents/Resources/arduino-builder/tools" -tools="/Users/testuser/Library/Application Support/xod-client-electron/packages" -fqbn=“arduino:avr:uno” -build-path="/Users/testuser/Library/Application Support/xod-client-electron/upload-temp/build" “/Users/testuser/Library/Application Support/xod-client-electron/upload-temp/xod-arduino-sketch.cpp”
open /Applications/XOD IDE.app/Contents/Resources/app.asar/src-babel/workspace/ardulib: not a directory
"/Applications/XOD IDE.app/Contents/Resources/arduino-builder/arduino-builder" -hardware="/Applications/XOD IDE.app/Contents/Resources/arduino-builder/hardware" -hardware="/Users/testuser/Library/Application Support/xod-client-electron/packages" -libraries="/Applications/XOD IDE.app/Contents/Resources/app.asar/src-babel/workspace/__ardulib__" -tools="/Applications/XOD IDE.app/Contents/Resources/arduino-builder/tools" -tools="/Users/testuser/Library/Application Support/xod-client-electron/packages" -fqbn="arduino:avr:uno" -build-path="/Users/testuser/Library/Application Support/xod-client-electron/upload-temp/build" "/Users/testuser/Library/Application Support/xod-client-electron/upload-temp/xod-arduino-sketch.cpp" (exited with error code 1)
Oh, looks like our bug in distro packaging. Will release a hotfix next Monday. Meanwhile all I can suggest is copying/pasting/uploading through Arduino IDE
The fix is out! Please update to 0.24.1 and all should be working again.
No problem with upload now, thanks :+1:
