Do not allow over-ride of default nodes
Not sure if this is a good idea or not, but it does seem to result in a lot of people breaking their XOD installation unintentionally.
There might be the rare case where someone really does want to over-ride the built-in nodes for all programs they run, but in general, if you want a new implementation of a built-in node, you should be creating your own node for the customization, especially when future versions of XOD are likely to need updated copies of built-in nodes and changing one built-in node results in a copy of ALL built-in nodes in that folder getting copied to your workspace.
Maybe a compromise would be to allow an over-ride folder to be created in your workspace (manually), but giving an error if anyone tries to save a change to a built-in node so they can’t do it accidentally? This might mean that you can’t even make a change to a built-in node since you don’t want to prevent users from saving their project, but that might be harder to code…you do want to be able to view built-in nodes to see how they are coded and make copies of the code. Maybe the over-ride for the built-in node could just be saved as a local node for the project (changing the path for the node when a built-in node is modified, but what do you do with other copies of the built-in node for this project)?
Sorry…this idea seems to have more questions than solutions, but it seems like something that should at least be considered since it has resulted in broken XOD installations after upgrade for so many people.
@gweimer
Me parece que todas sus preguntas son muy válidas para la mejora continua de XOD.
Me he puesto a experimentar todo lo que usted dice y más, confirmo sucede todo lo que usted dice con mucha facilidad.
En el ultimo tiempo estoy tratando de traer más usuarios a XOD, pero muchos han abandonado el paradigma que se propone desde aquí.
Antes de escribir este mensaje recogĂ­ un poco de estadĂ­sticas preguntando a la gente que conozco que utiliza XOD y en particular los que abandonaron, me interesaba saber las causas. Aunque son muy pocas muestras se puede inferir lo siguiente.
a) 3 de cada 4 abandonos son principiantes.
b) todos ellos pasaron por al menos algo de lo que usted dice. Sintieron mucha frustraciĂłn al no poder o saber revertir su error.
c) Todos los que pasaron por lo dicho en (b) se hacen las mismas preguntas que Ud.
Yo agregaría unas preguntas más:
Âżcuales son las tasas de nuevos usuarios?
ÂżQue tan activos son dentro de XOD?
ÂżQue polĂ­ticas de captaciĂłn y de retenciĂłn de usuarios incluyen la interfaz de usuario y la experiencia de usuario?
Esto que plantea usted ÂżayudarĂ­a tener una mejor experiencia de usuario, la captaciĂłn y la fidelidad de ellos al paradigma de XOD, ayudando a hacer crecer mucho mas esta comunidad?
Saludos a todos. :wave:
