hello everyone
i have tried using the dc motor driver from the ''nkrkv ‘’ library and it’s not functioning properly. it just shows a block that i cannot connect to anything. Am i doing something wrong or is there some other problem? thank you
hello everyone
Hello and welcome!
Would you provide more details?
nkrkv/af-motor or something other?The error in the console is not related.
OK, xodball?
Also, would you double-click the dc-motors node to drill-down into it’s implementation and make a screenshot?
As an extra data-point, I just added that library and the dc-motor node has 4 input pins & I don’t see the error for dc-example.
Maybe it would help if nikolaz deleted the XOD\__lib__\nkrkv\af-motor folder and re-added it? It sounds like their copy is corrupt.
hmm… so it seems i am the only one who encounters this problem , so yeah propably i have downloaded a corrupted copy
i re-installed the library and its working fine now! just some weird glitch i reckon. thanks a lot for your help and sorry i wasted your time for a seamingly simple solution
The guy who invented MD5 hash sums to check downloaded files integrity done it not only to overcomplicate things but also for something useful.
