Can't load the first program
При загрузке первую программу (урок 101 upload ) возникает ошибка в конце:
flush start
setting serial port timeouts to 1 ms
setting serial port timeouts to 1000 ms
flush complete
espcomm_send_command: sending command header
espcomm_send_command: sending command payload
read 0, requested 1
warning: espcomm_sync failed
error: espcomm_open failed
error: espcomm_upload_mem failed
Error: exit status 2
Error during upload.
Upload failed
Но подобная программа грузится из ArduinoIDE и работает .
Поможете?
XOD is not able to find your Arduino board. Since it works with IDE, I would assume your cabling and board are good. After selecting upload, a screen pops up and you have to select the type of Arduino and the port it is connected to. I would have to assume one of these is not being set correctly.
