Perche questo messaggio
quando carico il programma su arduino usando xod da liux mi appare questo messagio
Upload failed
Come posso risolvere il problema?
XOD is unable to find an Arduino board to download the code to. Verify that the board is connected to the computer and you are selecting the correct interface to download to. It is difficult to provide much more help than this. Do you have a way to verify Linux can see the Arduino board is connected?
