Arduino uno R4 minima
Hi there.
Just got Arduino uno R4 minima. There is problem with output ports, they are react together. D2&D11, D3&D12, D10&D13 is affected each other. I have to try with IDE port by port and was working fine.
Thank you wery much for help.
There is another problem with Uno R4 minima.
Uploading: blad kompilacji.jpg…
The same error in Arduino Uno R4
Today , different info
Performing 1200-bps touch reset on serial port COM7
“D:!\Arduino\Xod_packages_\packages\arduino\tools\bossac\1.9.1-arduino5/bossac” -d --port=COM7 -U -e -w “C:\Users\darro\AppData\Local\Temp\xod_temp_sketchbookOPth2Q\xod_1712359639495_sketch\build\arduino.renesas_uno.unor4wifi/xod_1712359639495_sketch.ino.bin” -R
No device found on COM7
Set binary mode
Send auto-baud
Set binary mode
Error during Upload: uploading error: uploading error: exit status 1
Upload failed
At the Arduino IDE works good on the port COM7
I had a similar issue with the R4 wifi, I think the most likely cause of this error is that trying to compile code that is meant for an AVR-based Arduino board (like Uno, Nano) on a board that uses a different architecture, such as ARM. When I connected the R3 uno, it compiled, uploaded and worked great but would not compile for the R4. Just throwing it out there as this is what I came across. Also had to make sure my cable was a data cable and not just a charge cable, some USB-C only charge.
XOD is using AVR-tools to do the compiling, so it is unlikely to work with boards not using AVR
I have been thinking is somethink like this You say, but. How that come: all nodes are working /RTC, Dislays, key boards atc atc, just DIGITAL WRITE is not working at all, but LED node is working in nonproper way /ports are affecting each other/
THNKS for any suggestion.
