Upload error: "No device found on comX"
New to XOD and Arduino, just got my Uno Rev 4 WIFI board, can’t get anything to upload. I can upload just fine with Arduino IDE program, can also use “show code for Arduino” within XOD, copy and paste into IDE, then upload it successfully that way. Log is below:
Performing 1200-bps touch reset on serial port COM5
“C:\Users\Owner\xod_packages_\packages\arduino\tools\bossac\1.9.1-arduino5/bossac” -d --port=COM5 -U -e -w “C:\Users\Owner\AppData\Local\Temp\xod_temp_sketchbookDWxDB4\xod_1705024266647_sketch\build\arduino.renesas_uno.unor4wifi/xod_1705024266647_sketch.ino.bin” -R
No device found on COM5
Set binary mode
Send auto-baud
Set binary mode
Error during Upload: uploading error: uploading error: exit status 1
Upload failed
Do you need to select a different serial port when doing the upload? Does IDE find board on COM5 or somewhere else?
It seems to find it automatically, and device manager shows it on COM5, and Arduino IDE connects over COM5. I even changed the COM port manually in device manager to make sure some other program wasn’t using that port.
The only other issue I can think of is that you have wrong board selected when you download, so it is trying to use the wrong protocols to connect.
