Cant upload to osepp uno R3orR4
No new serial port detected.
esptool v0.4.13 - © 2014 Ch. Klippel ck@atelier-klippel.de
setting board to nodemcu
setting baudrate from 115200 to 9600
setting port from COM1 to COM3
setting address from 0x00000000 to 0x00000000
espcomm_upload_file
espcomm_upload_mem
setting serial port timeouts to 1000 ms
opening bootloader
resetting board
trying to connect
flush start
setting serial port timeouts to 1 ms
flush complete
espcomm_send_command: sending command header
espcomm_send_command: sending command payload
read 0, requested 1
trying to connect
flush start
flush complete
read 0, requested 1
trying to connect
flush start
flush complete
read 0, requested 1
resetting board
trying to connect
flush start
flush complete
read 0, requested 1
trying to connect
flush start
flush complete
read 0, requested 1
trying to connect
flush start
flush complete
read 0, requested 1
resetting board
trying to connect
flush start
flush complete
read 0, requested 1
trying to connect
flush start
flush complete
read 0, requested 1
trying to connect
flush start
flush complete
read 0, requested 1
warning: espcomm_sync failed
error: espcomm_open failed
error: espcomm_upload_mem failed
Error: exit status 2
Error during upload.
Upload failed
To add,
Tried on windows 7 and windows 10. Do not know what the things mean on upload project to arduino, tryied different setting …does not seem to matter. code works fine if i copy and upload with arduino ide 1.8.12
But there you have 4D system … select the dropdown list Arduino UNO
cesars,
Sorry wrong screenshot went through all possible setting. I am re-installing xod right now will try again after its done. fingers crossed
Turns out it was the same ADMIN issues on both computers. Reinstalled and working fine now. If your wondering why two computers win 10 is surface pro portable… win 7 on home computer.
