Did I do it right? Is there a way to stop the sequence from happening at boot? And to only start when the button is pressed.
I am not sure what the turorial number is, with little data it is difficult to help
204-run-for-x-seconds
Here you have two options among many, keep in mind if the active button with low or high
I had it set up like no. 1. I tried changing the false and true values around on both the button node and the delay node and still the led will light up at boot for the delay time. I changed the configuration to no. 2 and it worked correctly with the tweak-pulse. The led did not light up at boot. How do I get it to where the button configuration works like that?
the button must be at GND, and res 10k a VCC
if you connect the button to VCC, and to GND, it will turn on at startup
button is activated with low
I tried removing the button from the breadboard and even with no button on the breadboard the led light will still come on with delay at boot up.
