Hello,
I have a problem.
i had 5 motors on a delay timer.
when i boot my arduino all the delay timers will be actief
Is there a solution?
Hello,
I have a problem.
Hello!
Would you provide more details?
Hey, i have the same problem, please help me how i can set set delay node.
I must set boot>>>LED not blink i pressing button>>>LED blinking 10s
change D0 to another pin, you are using it in debug
i changed to D8 nothing hepend better. boot>>> LED(in my case relay) blink without press button:(( I cant past program to post
Cesar please help me!
delay2|290x500
this only option?
The simplest thing NOT WORKING…
there will always be 0, use delay + flip-flop (pin toggle)
https://i.ibb.co/6yJbQDv/delay.jpg whay delay starts in simulation on start??
in that image I see that it uses pin 0, 0 and 1 are debug TX and RX
ps: use pull-up resistor if button no have
