I use the library emiliosancheza/bme280-sensor/sensor-bme280. When I run the project I get an error
Building…
/ws/sketchbook/f067fc25bccdee58bc4d550b70da0bbb4673edc9e916315127e31c9e4e6aac9c/sketch/sketch.ino:980:10: fatal error: ‘Adafruit_Sensor.h’ file not found
The file was found on GitHub adafruit/Adafruit_Sensor.
How to get rid of the error?
While XOD allows you to simulate microcontroller boards, it doesn’t have the capability to simulate additional hardware devices such as your bme280 sensor.
Adafruit_Sensor.cpp and Adafruit_Sensor.h should have been installed automatically when you added the emiliosancheza/bme280-sensor library to the XOD IDE. The simulator cannot “see” these files (that’s why you received an error), but they should be present if the library installation was successful.
Try uploading the patch called example-test-sensor-bme280 to your microcontroller board. Remember to tick the checkbox “Debug after upload” so that you can see the sensor readings in the watch nodes.
If you’re new to XOD I’d recommend working through the built-in tutorials. Another useful resource for self-paced learning is: Rapid Prototyping
