Seeedstudio Motor Shield
Looking for any usage guide on the Seeed Studio Motor Shield V2.2. I’ve tried using the native H-Bridge node as well as the nkrkv/af-motor node library. It either isn’t compatible or I haven’t figured it out quite yet. Thanks.
Looks like it should work with the H-Bridge node. The wiki page for it gives pins to use: http://wiki.seeedstudio.com/Motor_Shield_V2.0/
Besides suggesting you have not configured the pins correctly, there is no way we can know what you might be doing wrong without seeing what you are doing. A screenshot of your patch, including the inspector view of the h-bridge giving port #s would help.
