I am new to XOD and i am facing a problem, when i use flip-flop an error occurs and does not allow my code to deploy to my pro mini. please help
“Dead reference error Patch “xod/core/cast-to-pulse(boolean)” is not found in the project.”
Although they are different types, an implicit cast exists. For some reason, the system can’t find a node for the implicit cast.
I bet you have a stale copy of the standard library. Please, check directory %HOME%/xod/__lib__/xod. If it is there, delete or move it out of __lib__
I am having an issue using the flip flop node. I use two button nodes as inputs, “set and reset”. the flip flop node and the LED node. Found that I need to hold button inputs hi and switch to low, I use a 1K for pull up resistors. Used different pins, arduino UNO and two different arduino megas with no success. I also found that I cannot just turn on a Led deploying the single led node set to “1” from XOD. seemed to happen after the last update? Everything works as normal when using the old painful arduino ide. Suggestions?
