No Serial output in XOD
Hi, I get no output in XOD serial window. Neither following “upload and debug” nor if I connect through Deploy>Connect serial menu.
I can still connect to my Arduino with ArduinoIDE serial monitor and everything seems to work pretty well with the code uploaded from XOD.
Thanks for any help.
Have you tried uploading code, opening serial window, then pressing reset button on Arduino? I know I have problems with debug mode where watch nodes will not update after upload until I reset board.
Tried resetting, unplugging - xod serial window remains empty.
ArduinoIDE serial monitor works perfectly
