Hi Victor,
First of all : Thank you so mutch for making this program.
this makes programming look easy:))
When i use the new uart-example nodes I get an error during Deployment.
I dont know if I did somthing wrong, but here is wat I did:
I copy/pasted the uart-example nodes into the main patch of a new project, and clicked ‘upload to Arduino’ (an Arduino uno), and got this error message:
· Transpiling…
· Project was successfully transpiled. Searching for device…
· Port with connected Arduino was found. Installing toolchains…
· Toolchain is installed. Uploading…
Upload failed. ChildProcessError: Command failed: “C:\Users\Jeffrey\AppData\Local\Programs\XOD IDE\resources\arduino-builder\arduino-builder.exe” -hardware=“C:\Users\Jeffrey\AppData\Local\Programs\XOD IDE\resources\arduino-builder\hardware” -hardware=“C:\Users\Jeffrey\AppData\Roaming\xod-client-electron\packages” -libraries=“C:\Users\Jeffrey\AppData\Local\Programs\XOD IDE\resources\arduino-libraries” -tools=“C:\Users\Jeffrey\AppData\Local\Programs\XOD IDE\resources\arduino-builder\tools” -tools=“C:\Users\Jeffrey\AppData\Roaming\xod-client-electron\packages” -fqbn=“arduino:avr:uno” -build-path=“C:\Users\Jeffrey\AppData\Roaming\xod-client-electron\upload-temp\build” “C:\Users\Jeffrey\AppData\Roaming\xod-client-electron\upload-temp\xod-arduino-sketch.cpp”
C:\Users\Jeffrey\AppData\Roaming\xod-client-electron\upload-temp\xod-arduino-sketch.cpp: In function ‘void xod::xod__uart__uart::evaluate(xod::xod__uart__uart::Context)’:
C:\Users\Jeffrey\AppData\Roaming\xod-client-electron\upload-temp\xod-arduino-sketch.cpp:895:49: error: ‘SERIAL_PORT_HARDWARE_OPEN’ was not declared in this scope
state->uart = new (state->mem) HardwareUart(SERIAL_PORT_HARDWARE_OPEN, (uint32_t)getValue<input_BAUD>(ctx));
exit status 1
“C:\Users\Jeffrey\AppData\Local\Programs\XOD IDE\resources\arduino-builder\arduino-builder.exe” -hardware=“C:\Users\Jeffrey\AppData\Local\Programs\XOD IDE\resources\arduino-builder\hardware” -hardware=“C:\Users\Jeffrey\AppData\Roaming\xod-client-electron\packages” -libraries=“C:\Users\Jeffrey\AppData\Local\Programs\XOD IDE\resources\arduino-libraries” -tools=“C:\Users\Jeffrey\AppData\Local\Programs\XOD IDE\resources\arduino-builder\tools” -tools=“C:\Users\Jeffrey\AppData\Roaming\xod-client-electron\packages” -fqbn=“arduino:avr:uno” -build-path=“C:\Users\Jeffrey\AppData\Roaming\xod-client-electron\upload-temp\build” “C:\Users\Jeffrey\AppData\Roaming\xod-client-electron\upload-temp\xod-arduino-sketch.cpp” (exited with error code 1)
I tried replacing the uart input node with the other ones (uart-0, uart-1, uart-2, uart-3 and uart-usb) but i get the same result.
I hope this is enough info
Greetings,
Jeffrey
