Need implementation of SSD1306Ascii in XOD
Hi all!
I need implementation of OLED1306ASCII library in XOD
for use with low memory boards
Can anybody help?
wayland/ssd1306-oled-i2c — XOD library already exists, but it wraps Adafruit_SSD1306 (GitHub - adafruit/Adafruit_SSD1306: Arduino library for SSD1306 monochrome 128x64 and 128x32 OLEDs), so it might use too much memory for you. You might be able to use it as a template for creating your own wrapper for the ASCII library even if it doesn’t work for you.
i tried using instruction but kept getting error
error: no matching function for call to ‘SSD1306AsciiAvrI2c :: SSD1306AsciiAvrI2c (const DevType *, uint8_t &)’
Type oled = new (mem) SSD1306AsciiAvrI2c (& Adafruit128x64, i2cAddr)
Do you have pragma to include the SSD1306Ascii library? That is where that function should be defined. There are general instructions for wrapping IDE libraries Wrapping Class-based Arduino Libraries — XOD, and the wayland library I linked to above will probably be pretty close to what you want, making it a good template/example.
I’m afraid I can’t help you much beyond that since I don’t have experience with the process.
of course
trouble in → Type oled = new (mem) SSD1306AsciiAvrI2c(&Adafruit128x64, i2cAddr);
#pragma XOD require “GitHub - greiman/SSD1306Ascii: Text only Arduino Library for SSD1306 OLED displays”
#include “SSD1306Ascii.h”
#include “SSD1306AsciiAvrI2c.h”
node {
meta {
using Type = SSD1306AsciiAvrI2c*;
uint8_t mem[sizeof(SSD1306AsciiAvrI2c)];
void evaluate(Context ctx) {
    if (!isSettingUp())
        return;
    uint8_t i2cAddr = getValue<input_ADDRESS>(ctx);
    emitValue<output_DEV>(ctx, oled);
Solution found
Topic can be closed
You are not going to share your solution?
Sure.
When everything is completely ready
