Nano will not load simple program
ATmega328PU CH340 is the nano board I’m using. Is this compactable with XOD. It will not load the program using the Arduino Nano ATmega328P. Am I using the correct “Board model” and “Processor”? Do I need to load drivers? If so, which ones?
I tried a new cable. Same story. I still get the message below.
As part of the download, you have to select port to use as well as board type to download to. Make sure you have the correct options selected. There are several nano options you can try in the list.
Still not working. I selected Nano, ATmega328P. The title of the one i bought is ATmega328PU. does the U made the difference?
I’m going to chock this one up as a bad board and move on.
