Hello an thank you all in advance for your time and help! Noobie here that has been trying to use XOD, to program my Arduino to create a gate system. The system has multiple inputs (16 in this case) that use a Dwyer CCS12050 (non contact current switch) and a equal number outputs that will be to 5v relays. I want each input to be able to open one corresponding output while at the same time closing any other open . Thus having only one (the most current) output open at a time.
In order to try and learn/use XOD I am prototyping the system using buttons and LEDs on a breadboard. The XOD patch I have come up with is here:
The buttons just behave like normal – LED on when pressed and off when pressed again with no interaction from one to the other. Am I way off base? Any guidance would be appriciated!
Thanks!
