Moisture sensor
Will i be able to use the moisture sensor in Xod. Can’t seem to find it.
Hello and welcome?
What sensor model do you use? Most of them look and operate very similarly, but has different characteristics of components that lead to different output range scale.
I suggest starting with a simple analog-input and observe how your particular sensor behaves. Add a watch on its output, upload with debugger, and take a look what values it gives when it is dry, semiwet, and wet.
